• CAD SCHOOL
    by Cizim Okulu
    Register or Login
Category Index
LISP to Export Tables...
AutoLISP Function to ...
Automatically generat...
FreeMUST v3.1 Archite...
Facade elevation assi...
AutoLISP Function for...
AutoLISP Function Tha...
Automatically writes ...
Point Coordinate Extr...
Visitors: 1, Users: 0
Details »
AutoLISP > AutoLISP Function to Create Point Coordinate Table
AutoLisp, Function, Creating, Point, Coordinate, Table, AutoCAD point table lisp, export coordinates to excel, create coordinate table
admin - 20.05.2026 05:39
## AutoLisp Function for Creating Point Coordinate Table (Improved Version)
An upgraded and enhanced version of the previously shared AutoLisp function, redesigned based on the high interest and feedback from the community.
This professional tool automatically creates a comprehensive Point Coordinate Table from Point or Circle objects residing on a user-defined Layer. It perfectly formats the data according to your specified text height and decimal precision.
## ???? Key Features
* Smart Numbering Options: Sort and number point coordinates in the table by Row, Column, or the Creation Order of the objects.
* On-Drawing Labels: Optionally print point numbers right next to the corresponding objects on the drawing.
* Prefix Support: Use alphanumeric prefixes (e.g., P1, N1, PT-1) or use numbers only.
* Memory Function: The function remembers your last used point number, text height, and decimal precision until the drawing is closed. Just press Enter to skip and use the default suggestions.
* Dynamic Placement: Once initial settings are configured and objects are selected, the completed coordinate table instantly appears on your screen. Simply drag and click to place it anywhere in your drawing.
* UCS & WCS Compatibility: Coordinate values are dynamically calculated based on the active UCS, while Row and Column sorting is accurately performed according to WCS.
## ???? What's New in This Version
* Excel Export: Now fully capable of exporting point numbers and coordinates directly into an Excel sheet.
* Flexible Text Placement: Added a new option to print point numbers either directly over the point or offset (alarga).
* Selection Set Support: Easily define the target objects by creating a custom selection set.
* Improved Alignment: When placing text directly over the point, the text justification is automatically set to Middle for a cleaner look.
## ???? Download Details
* Password: autocadokulu.com
* Tags: Nokta Koordinat Tablosu Oluşturan AutoLisp Fonksiyonu, AutoLisp Function for Creating Point Coordinate Table, AutoCAD Lisp Export to Excel, Point Table Creator
Author: cizimokulu.com
Description: AutoLISP Function to Create Point Coordinate Table
Tag: AutoLisp, Function, Creating, Point, Coordinate, Table, AutoCAD point table lisp, export coordinates to excel, create coordinate table
Hits: 3, Size: 0.05 MB
Comments :
No comment yet
SQL: 0.01 seconds - SQLqueries: 31 - Avarage: 0.00031 seconds
